Archicad design tools: Workflows, element connections, modeling tips
Special Menu and Panther
fuzzytnth3
Not sure if I am posting in the right section but here goes
In OSX 10.2.8 and earlier the Special menu was always visible (whether you wanted it or not)
In OSX 10.3 I can't find away to make it visible. I have tried holding down the Control key during start up of AC (and other combos in the vain hope it would work) but no luck.
Anyone else found away round this?
Cheers
Using AC25 5005 UKI FULL
2 REPLIES 2
__archiben
hold down 'Ctrl' + 'Alt' together at archiCAD startup. it stays on permanently until you turn it off in the same manner. it probably reset itself when you upgraded to panther?
there is a discussion about it here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=474&postdays=0&postorder=asc&start=0
use at your own risk . . .
~/archiben
b e n _ f r o s t
On a Mac it is the Command (Apple) + Option keys that enable the Special Menu. It is working fine for me in AC8.1 and OSX 10.3
