Special tools
Hello
I read that there is a "special tools" for AC 9. Where do get it from?
I found out about it here.
http://archicad-talk.graphisoft.com/viewtopic.php?t=7129&postdays=0&postorder=asc&highlight=offset&&...
Any help would be nice!
Stefan
Hej Stefan,
Stefan
Offset-verktyget som de pratar om på länken du givit har funnits i A.C länge (ligger i paletten bredvid/strax under Koordinatpaletten. Följ stegen på din länk ovan så kommer du att lyckas. Trollspöet kommer man åt genom att hålla Mellanslagstangenten nere under tiden man klickar på originalet.
TomWaltz
The tools in questions are a palette, usually found at the bottom of your working screen, called the "Control Box."
It has several commands, such as "mid-point," "nth-point divider," "perpendicular", and "offset."
If you click Window -> Palette Display -> Show Control Box, you should see it.
Tom Waltz
