no default fills
there are only 3 default fills in my archicad program (marker, solid, air space). should other default fills be loaded, or are all other fills manually created? where can i find other fills?
3 REPLIES 3
Hello
Make a "New and reset" and all the default fills will reappear…
i believe the fills have been missing since the installation of archicad. returning a new project to the default template hasn't helped...
Hava you really do a "New and reset" ?
You may maintain "Alt" button before go to the file menu. Then "new" become "New and reset".
Other way. You can open a file with the wanted fills, and go to "New" a message give you three choice use the first "use lasts…"
You may also use the "atttributes manager" to copy fills from another archiCAD file.
If you are in AC9, i can't help you more…
