Spider Connection?
Hi there, does anyone know where I can download a spider joint for grasping sheets of glazing in the corners?
I searched the forum only found one which had been mentioned before: at 3dsmile, however its not really what I want, I simply want the connection, and its also in italian and its hard to make out!
Thanks!
1 REPLY 1
Eduardo Rolon
check objects online under structural glass
www.objectsonline.com/customer/search.php?substring=structural+glass
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
