Splitting a roof
Can I split a roof?
I've got an exiting roof, part of which needs to be demolished. If I need to demolish part of an existing wall I can usually split it and change the renovation status of the section I need gone, but I can seem to do the same with this roof.
Any ideas?
5 Replies 5
Is it a single plane roof or multi plane? If multi plane you will have to split into single plane elements first, but yes, it can be done.
Thanks.
It's a multiplane roof, but in the end I made a copy of it, changed the renovation of the original to demolished and put the new one back as a proposed element and removed the bits I didn't want
How would you go about splitting a multi plane roof into single plane elements?
Lingwisyer
Guru
You can just right click on the roof and select "Split into Single-Plane Roofs"
Ling.
Ling.
Thanks Ling, that is exactly what I was looking for.
