Stair: Curved treads lines
Hi All
This is a basic question, is it possible to create a Stair with Stair Maker-maybe with the "create stair using selection" option and ending with a stair like this?
I've been doing it with Slabs, because the complex profile creates problems with the adjacent walls/beams.
Is there a way to create i with stair maker?
Thanks!
Nando
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
3 Replies 3
TMA_80
what if you put the created profile in a new layer then give this layer a different priority number (2 for example)
AC12_27 |Win11_64bit|
Thanks,
YEP, I've tried and it works , but it wont have the trimmed edges... and the SEO doesn't show on floorplans...
I'm trying now with a smaller section of the stair.... I'll postreply if I find a workaround
Nando
Nando Mogollon
[email protected]
TMA_80
NandoMogollon wrote:
Thanks,
Nando
well , once you've applied the SEO operation you could save the resultant shape as an object ...it should work .
