2022-03-10
09:45 PM
2023-05-09
03:10 PM
Rubia Torres
Seems that every AC version creates a new bug, Here's the latest...
1. AC25 Stair - When you modify an individual run width on a stair with multiple runs (switchback) the top tread disappears.
2. AC25 Stair - Custom tread settings cannot be "reset", you have to manually modify any customized treads to reset the tread to match other standard treads.
3. AC25 Railing - Handrail ends ignore 2D symbol visibility settings of handrails - So even if the handrails are set to be hidden and turned "off" on plan the handrail ends are still showing.
4. AC25 Railing - Sometimes the multi-level cutline set to be associated with the stair doesn't sync with the stair cutline. Very inconsistent and frustrating.
