Stair problem - again
Does anyone know what does this message error mean?
3 Replies 3
Erwin Edel
It means the nosing value set on the tread page of stairmaker is too large for the landing.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Dontknow
Do you mean by this that each tread is too lang which makes the whole stair too long?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Erwin Edel
In dutch it is the setting for 'wel' from the 'trede'
That value (nosing) is added to the depth ('aantrede') of each tread.
Stairmaker isn't adapt at making all the stairs you could actually make in the real world of stair builders. Especially when it comes to perceived problems with nosing in winders, at landings, etc.
If it's a quick draft, just set nosing as low as you possibly want. Sometimes I just put it at zero, to not have to deal with constant error reports trying to build a basic stair.
www.leloup.nl
