Stair skirting
Hello,
How can I make a stair skirt. I have tried stringers to get it and convert it to mroph but it dose not work.
Should I model .
thank you.
1 REPLY 1
Podolsky
Ace
In stair skirting important to know the length (especially when you have a lot of stairs). This information goes to estimation. So better way is to model skirting from inclined beam. You can then cut bottom of the beam with the stair (SEO). Beam also will give you correct length.
