First of all, thanks to everyone who will take their own time to read about my problem and help. I am designing a fairly small house for my End Thesis project. I have used on another project for my end thesis the stairs, and have also on this particular file used them successfully.
The problem is, I had to delete "the old" stairs, and redo them... and after redoing, what happens is that they simply refuse to show on 3D View. They remain as the profile the stairs will have, but never get completed as a solid object. They do show on the plans correctly, but on section view they also display as blue lines.
I have tried to look into it before asking, without much luck. I found some people had a similar problem in some posts last year, but the 5021 Update was supposed to fix this, so I guess either I am doing something wrong ( and cannot figure out what ), my file got corrupted ( and I cannot find how to clean it ), or I stumbled into something diferent.
After that, I also used the railing took for a makeshift fence, just so that in section cuts I can be made aware of the solid limits of the lot, while still designing ( I am nowhere close to a finished documentation set yet ).
https://www.dropbox.com/s/83okm706kqz51lu/StairAndRailing004.jpg?dl=0https://www.dropbox.com/s/l6bzr60x2x9724v/StairAndRailing005.jpg?dl=0Thank you so much for any help, I will keep researching, but I already spent a good portion of a good day in this and am going a bit crazy
