Story Levels not showing
I have a problem where the lines for story levels are not showing (neither for display nor output). They are turned on in story settings so I don't know why, is it possible that another setting overrides this?
See attached screenshots
1 Solution
Did you check the checkboxes ( ) on the Story Settings Dialog Box?
(The ones at the end of each Story)
Go to post
2 Replies 2
That was it, thanks!
