Story Levels
I'm doing my senior thesis design on archicad... I have never done a multi level story building. Can anyone tell me what is the measurement between floors is it 1'?
6 REPLIES 6
You cannot be serious with this question? What school/program are you in?
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
im dead serious. Its a failing school that is going out of business. i'm sorry. but can you just tell me what is the dimension?
Dwight
with your total lack of information, 1' is as bad a guess as any.
Dwight Atkinson
I'm remodeling an existing space that was formerly a school.. The building is a two story building. I need to know the amount of space I need to separate the two floors that are on top of each other.
Dwight
What is the structural system? Where are the lights and mechanical systems hidden? What are the spans? The floor loads?
If you specify 1', that is equal to the nominal distance of a 2x10 wood frame floor with topping and a ceiling below.
It could be an 8" thick concrete slab.
Or whatever.
Your question is like asking "how long is a piece of string?"
At your level of appreciation, leaving 1' is close enough.
Dwight Atkinson
Thank you for your help!
