Eman
Stretch an Image
Can I stretch an image in Archicad?
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
1 Solution
If you place an image using the 'Figure' tool, you can stretch it around however you want.
Go to post
7 Replies 7
runxel
If you absolutely have to, place the image, select it and safe it as an object.
Then place it with the object tool – you now can stretch it.
Eman
Hi runxel,
I saved it as an object. then placed it with the object tool as you said but the object (the image that I saved as an object) that I place it is showing only white.
Eman / Draftsman
runxel
Maybe the image is in a weird format?
Or it has transparency?
Eman
I tried 2 formats, jpeg and png files and with no transparency.
Eman / Draftsman
Eman
Hi Barry, yes that works perfect.
Thanks very much.
Eman / Draftsman
runxel
Hah, sometimes the good is just a click away. The figure tool is banned from my work environment, but it seems there is a reason to have it after all.
