Stephania
Stretch cabinets height, makes archicad gets stuck
Hi!
I recently downloaded ArchiCAD 27. Before it was really easy to stretch the height of a wall cabinet in the 3d or interior elevation but now whenever I try, ArchiCAD gets really slow, gets stuck and just wont stretch the cabinet to a desired reference point. Any solution for this?
Thanks!
11 Replies 11
hevi
Ace
Can confirm this behaviour when using stretch height on objects in 27.1.1 on windows.
Roger C
Can confirm this behaivour too in Archicad 27.1.1. This needs a solution ASAP.
i7 3770K / MSI GS73VR 7RF i7 7700HQ
16 gb
GTX 3060 / GTX 1060
Windows 10
ArchiCAD 25 SPA
Stephania
I have 4001 USA FULL ArchiCAD 27.
Stephania
Looks like the same issue happens with other "Objects". I doesn't happen with walls, slabs, windows, doors. But it doesn't happen with all objects. I was able to stretch the height of a chair.
Stephania
how?
@Stephania wrote:
how?
@Stephania ,
There was no solution by the person you replied to.
That was a spam post just so they could place a link to something unrelated to Archicad in their signature.
That post and user has been removed.
JJMARQUEZ
Make a copy of the object and select both. You will see that now it works. You can also select any two and it will work.
Vaclav Slovak
Here the same problem - please solve it as fast as possible. very annoying 😞
karinamdp
This is still happening with Archciad 28.1.1
AC29 INT & POR
Windows 11
