‎2007-12-17 12:46 AM
‎2007-12-18 09:14 PM
s2art wrote:He's
And Karl, since when was Yoda an autobot?
‎2007-12-18 10:15 PM
s2art wrote:By RCP mode are you referring to setting the Story Viewpont Type to Ceiling Plan in the Model View Options, to change the appearance of your GDL Objects?
Link
I think Chris is saying "view the floor below (in RCP mode) and show the floor framing overlaid on it" still looking down, as your framing sits on the walls below. That's the way we do it here, seems to work o.k. for us.
‎2007-12-18 11:09 PM
Link wrote:Yes, MVO's but not necessarily relating to GDL objects, just to show walls as continuous over openings "Show opening only, with contours"s2art wrote:By RCP mode are you referring to setting the Story Viewpont Type to Ceiling Plan in the Model View Options, to change the appearance of your GDL Objects?
Link
Link.
‎2007-12-18 11:15 PM
s2art wrote:Oh right. Well that's what I do too.
‎2007-12-19 08:07 PM
s2art wrote:exactly!!
Link
I think Chris is saying "view the floor below (in RCP mode) and show the floor framing overlaid on it" still looking down, as your framing sits on the walls below. ......
‎2007-12-21 05:16 PM
‎2007-12-21 06:26 PM
Jefferson wrote:It is a very nice approach but I do not understand why the following single approach is not taken:
..........ghosting separate floors, above and below......
‎2007-12-21 07:30 PM
Joseph wrote:That's the approach I take as well, but for step #4 - wouldn't that mean that those upper level elements would then show up on all other plans in addition to the framing plans?Jefferson wrote:It is a very nice approach but I do not understand why the following single approach is not taken:
1. All framing members of the 2nd floor to be placed in 1st story (on structural layers)
2. RCP view be set
3. A desired pen set for supporting walls to be set up once (thin lines/Gray Scale/Color...)
4. Element (walls columns/Objects) from story (or stories) above to be shown on this plan, to be set in Settings window of appropriate elements.
Am I missing your point?
Thanks,
Joseph
‎2007-12-21 09:12 PM
Chris wrote:True, yet I have Structural (core of) & Architectural column layers (skin & finish) which I turn on/off appropriately. Often when a beam is carrying a column from above is shown on this supporting beam with structural considerations attached to it.Joseph wrote:Jefferson wrote:It is a very nice approach but I do not understand why the following single approach is not taken:
2. RCP view be set
Thanks,
Joseph
‎2007-12-21 10:10 PM
