2009-03-17
02:11 PM
2023-05-25
04:55 PM
Rubia Torres
2009-03-17 07:59 PM
2009-03-17 09:52 PM
Dwight wrote:yes, but this hurts when dealing with doors and windows, not so complicated, just some attention .
As for needing to place objects above the floor level - use gravity to slab. It automatically finds the highest slab under it.
2009-03-17 11:47 PM
Achille wrote:Why? You can make the story heights whatever you like and place the elements within them, no?
2) Cons:
The story level height corresponds to the concrete slab elevation and not on the finished floor.
2009-03-18 11:05 AM
2009-03-18 12:03 PM
2009-03-18 01:39 PM
Achille wrote:I can see how the display option may seem like a good solution, but it's really only a band aid solution at best. By it's very nature you are merely changing the display in that viewpoint. Any other sections or elevations would also require such display manipulation which is quite an overhead. The model is still incorrect however as you have two elements invading the same space. Just check your 3D Internal Engine Hidden Line view to see. The only way to make sure the model is accurate is by SEO.
@Link no you do not need SEO, just select walls and bring to front, and you have the result you see on the image.
And i understand that you do not use the subfloor thickness option of doors and windows.
2009-03-18 02:23 PM
2009-03-19 10:31 AM
Link wrote:Yes the 3d model will not be correct, but you will need SEO even with the second method...
2009-03-19 06:51 PM
Achille wrote:If you are moving walls around, then you should be using the marquis tool. This will also move the topping slabs, ceilings etc.
Since the interior walls start at the concrete slab, you either create a floor slab for each room (cumbersome if you move any wall)
