EugenioCespedes
PROBLEM WITH MEP IN LINKED MODULES AND THE PLN FILE AS A LINKED MODULE
I have the following problem: I have a MOD file where I create MEP routes with their nominal diameters and all the necessary configurations. They work correctly, but when I open the host file, all the MEP installations change, and the MOD file configuration is lost. I thought that if I took a floor from the host file and used it as a linked module, the problem would be solved since it's in the same file, but the MEP element configurations also change. Do you have any suggestions for fixing this?
0 Replies 0
