clauds1223
Surface fills
I turned on surface fills for my floor slabs in the floor plan views but when I go into elevation, those vectorial surface fills show on the floor edges though I don't want them to show. I want to turn on surface fills in my elevations because I want my walls to have a fill. How would I sort this?
2 Replies 2
CosminF
graphic override rule on all slab surface fills?
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Those fills show on Slab Edges in Elevations because those are the fills that are assigned to the Surface attribute those Slab edges are using.
You could select the Slab and assign some other Surface to the edges, a Surface that does not have a vectorial fill assigned to it.
