2026-08-04
09:43 PM
- last edited
a month ago
I turned on surface fills for my floor slabs in the floor plan views but when I go into elevation, those vectorial surface fills show on the floor edges though I don't want them to show. I want to turn on surface fills in my elevations because I want my walls to have a fill. How would I sort this?
2026-08-04 10:35 PM
graphic override rule on all slab surface fills?
a month ago
Those fills show on Slab Edges in Elevations because those are the fills that are assigned to the Surface attribute those Slab edges are using.
You could select the Slab and assign some other Surface to the edges, a Surface that does not have a vectorial fill assigned to it.
