Palawat
Symbol Label Suit for AC 21, 20, 19
Hi everyone,
I've created a label that shows Building Material, Building Material ID, Surface, etc. and display that info in a shape (Triangle, Rectangle, ...). It also create log files ( simple .txt files) , if enabled, that can be read by another object that will automatically create legend of symbol.
https://www.indigofigs.com/symbol-label-suit/
There's more info in "Features & Tips" on the page.
Feature Added :
(23 Jan. 2018)
For Building Material and Building Material ID of Composites/Complex Profile elements, user can select which skin to be displayed (other than the previous "Inside/Outside" choices.) (Available for Symbol Label Suit 21)
(9 Dec. 2017)
It is now possible to save symbol settings as favorites for various element types (Wall, Column, Slab, Door, etc.)
The options for independent label are the ones with “*” prefix, for example, “*Surface ID (Manual Select)”.
(6 Dec. 2017)
In case of Complex-profile Wall/Beam that is not cut by “Floor Plan Cut Plane”, 2 options, “Building Material (Manual Select)” and “Building Material ID (Manual Select)”, are added. (Available for Symbol Label Suit 21)
For Symbol Legend, file path detection is added. This forbids log file path 2 to use the same path as log file path 1.
Archicad 29, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.facebook.com/indigofigs
4 Replies 4
Palawat
Updates :
All known issues have been fixed.
I've also added the suit for ArchiCad 19. The download link is on the same page.
Palawat
Update :
This Symbol Label Suit is now available for AC 21.
Palawat
Update :
Feature Added :
(9 Dec. 2017)
(6 Dec. 2017)
Palawat
Update :
(23 Jan. 2018)
Important Note :
1. There are few parameters added/changed in this version (1.03). If you are using the previous version, please test it by copy your working file to a temp location then replace/re-link the library.
2. Backward migration script is not available. Meaning, if you decide to use version 1.03, there's no going back to 1.02 since some of the new parameters will be lost. So, again, please test it first.
