Zdenko
Diameter Dimension Labeling
does the "radial dimension tool" offer "diameter labeling", i know sounds like a silly question given the tool name? i assume no and further assume a text label is used with symbol notation. doing steel detailing and would like to speed up my process.
Operating system used: Mac Apple Silicon Sequoia 15.0.1
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
3 Replies 3
Lingwisyer
Guru
Just clarifying; you are wanting a label that shows "[diameter]  ⌀" rather than using a linear dimension line?
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
Zdenko
hi @Lingwisyer - if i select a circle with a unit radius of 10 using the "radial label tool" it will label it as such, but i need it to recognize that the diameter is 20 and can label it as a diameter not radius. looked online but does not appear to be any help and i know how to show the Ω ™ 😱 ⌀ various symbols.
Sequoia 15.1.1
BrunoH
Hi Zdenko,
You can do something like this with the dimension tool
 but it's not one click as you need to place a dimension.
ArchiCad 3.43 to 28
MacOS Monterey
