TIP-To Turn on A layer w/o Opening the Layer Setting
I know this is obvious but I though I share it any way:
I have always wanted to turn on an specific layer with out opening the Layer manager and scrolling through many layers just to turn on one desired layer. here I go:
Method One:
Make sure the wanted layer is alway Unlocked and Not Visible, then in the Info Box drop down the layer pop-out in any tool and start drawing. At this point AC will ask you if you want to make this layer Visible; click yes & the rest is history!
Method Two:
Choose the desired Layer with any tool and save it as a Favorite with the name of that specific Layer. Now if the layer combination has that layer not visible invoking the favorite and start to draw will ask for making the Layer visible..
Thanks to all the great people in this list server.
Joseph
10 Replies 10
But that method does not update your layer combinations, so next time you go back to that view the layer is off again...
At that point click on Settings of the and click on Get Current Window's Setting + OK.
Joseph
Laura Yanoviak
This still doesn't update your Layer Combinations, just assigns a "Custom" layer combination to your view.
Laura, you seem to be in the loop...
Have they fixed this in AC11?
Laura Yanoviak
I honestly don't know (I'm actually just outside the loop).
Link
No it hasn't been fixed, but IMHO there is nothing to fix. Just because a layer is turned on doesn't mean the layer combo is updated. You can see in the Project Map that the layer combination is Custom.
I would be careful using this method to redefine views, simply because mistakes can easily sneak in. Changes include all view settings including ID, name, layer combo, scale, pen set, model view option combo, dimension standards, and the all important zooming which sets the frame of the resulting drawings.
Each to their own of course!
Link.
Link.
I wouldn't suggest that layer combos were instantly updated by turning on / off a layer, but there should be an option to update a combo to the current layer settings. Maybe a "redefine" button that lets you select which combo to...uh... redefine.
Link
I agree 100% and think it should reside in the Layer dialog, not the view settings.
IMHO It's all part of a bigger consistency picture where all tools need to be aligned and made simpler and more consistent. In this example the WE profiles and schemes, favorites, attributes, including layers, and more would all have the same core functionality.
I've sent GS half a book on the subject...
Link.
Yes
Yes
Nice one, thanks. (You must have written a few books by now?)
But will (have) they listen(ed)?
