Tapering concrete beams
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-04-29
12:24 AM
2023-05-26
12:33 PM
Rubia Torres
2008-04-29
12:24 AM
I'm trying it again with a wall of similar dimensions...
I wish I could just drag the node of one corner in section, but it isn't working like that. I need a trapezoid shape in section.
Help?
Thanks again.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-29 02:29 PM
2008-04-29
02:29 PM
tdellaqu:
Use the Profile Manager to create the profile you want, then use it with the wall or beam tool.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-05-01 01:49 PM
2008-05-01
01:49 PM
tdellaqu wrote:I'm not sure if this question has been answered in the way you expected. Did you want the taper along the length of the beam, or in cross section?
how to do this? I tired rotating a beam and trimming the top off in section, but that didn't really work.
If it's the latter, you can shape many beam objects to a taper using OBJECTIVE's toolset (refer to the attached image). Note that when I refer to the Split or Rotate tools, I mean those under the OBJECTiVE/Tools menu - ArchiCAD's built-in Split and Rotate can't do this:
- 1. Place the selected beam in plan (in this example I used "Precast Beam I 01 11" from the standard ArchiCAD library) and place a section/elevation alongside.
2) Open the section/elevation and use 'Split' to divide the beam into an upper and lower section.
3) Use 'Rotate' to incline the lower section to the required taper angle.
4) Use 'Split' to cut away the unwanted parts of the lower section
- 5) Use 'Rotate' to incline the tapered beam to the required pitch
6) Use 'Spit' to shape the beam ends to the required angle (as applicable)
You can find out more about OBJECTiVE at:
Ralph Wessel BArch
Central Innovation
Central Innovation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-05-01 08:54 PM
2008-05-01
08:54 PM
Aha, thanks, I used both of your solutions in my project.
I also discovered that you can stretch a beam's angle and length by hitting the top points and using that pet palette.
Ok hopefully my signature attaches this time around
