Teamwork and Lost Data
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2003-12-19 01:14 AM
2003-12-19
01:14 AM
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-12-19 05:06 AM
2003-12-19
05:06 AM
Of course, the sooner you discover the problem the better. The solution isn't elegant by any means, but here goes...
1. Make sure that the other user(s) send & receive changes (and sign out if desired).
2. Let the user who lost the data sign in with exclusive access (not required, but useful).
3. Copy & paste the missing data from the draft file into the teamwork file.
4. Send & receive changes and everyone continues working.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-12-19 12:47 PM
2003-12-19
12:47 PM
Jay wrote:jay
. . . and now he can't get the changes he made back to the master file. How do we recover from this problem?.
have you
if you try to send and recieve, archiCAD may tell you something along the lines of: 'you are working on an earlier draft and sending changes will result in you losing the work sent on the later one'.
in this case it doesn't matter as the work on the earlier one had not been sent, and the later one
hope this doesn't sound too confusing.
good luck . . .
~/archiben
b e n f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-12-19 04:45 PM
2003-12-19
04:45 PM
~/archiben wrote:Does this mean that send/receive uses the saved copy of the plan on the hard drive (as opposed to what's currently in RAM)? It sounds like you sign-in and get everybody else's changes, then when you send & receive it writes the changes from your
have youtriedsending and receiving?
Or am I misunderstanding the sequence?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-12-19 05:15 PM
2003-12-19
05:15 PM
david
the send and receive uses the most current version of the file that you've been working on (what you call 'saved in the RAM', but probably is one of the many .SCRATCH files that archiCAD litters around).
what happens is thatafter you have sent and received your changes, archiCAD assigns a new number to your draft file (it starts at 1 and just clocks up until you sign-out - try looking at the 'teamwork notes' under the teamwork menu and you will see what's happening).
this makes it absolutely essential to saveafter a send and receive, (however since version 8.0.x and it's instability i have got into the habit of saving prior to sending and receiving too).
what i was referring to in my previous post was something that has happened once or twice here. . .
if archiCAD crashes when sending and receiving changesafter it has assigned you a new draft number in the admin file (usually kept on the server) but before that new draft number gets written to your local copy, your draft becomes out of synch.
if you try and send changes from this draft, archiCAD will warn you that it is out of date. this is a safeguard should somebody try with a genuinely out-of-date draft, however: in this case you know that the draft is not out of date because a crash caused it. so you can happily ignore archiCAD's warning and send those changes in anyway.
this may or may not be the case for you - as i said earlier, it depends upon when the crash happened, but it may be still worth a try to recover your data before trying 'major surgery'!
HTH
~/archiben
HTH
~/archiben
b e n f r o s t
