2008-05-19 10:38 PM
2008-05-19 11:16 PM
2008-05-19 11:33 PM
2008-05-19 11:54 PM
another Moderator
2008-05-19 11:54 PM
2008-05-20 12:04 AM
2008-05-20 02:22 PM
Rob wrote:I think the 'Pyramid' shape Peter recommended is likely to quickly and easily solve the problem. However, if you need to form shapes by cutting, take a look at OBJECTiVE, which includes tools to quickly and easily rotate and cut objects in 3D to the shape and orientation you need. I've attached a series of images showing a cube cut down to a tetrahedron. These operations can be done in plan or section, but in this case I stayed with the plan view:
Apparently a tetrahedron can be cut from a cube by cutting the six edges of the tetrahedron along the diagonals of each of the faces of the cube.
This would mean cutting through the section - can this be done with the marquee tool ? Or is there another way ?
Any advice would be appreciated.
