Texture direction resets when saving model as cust. comp.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2006-08-08
01:46 PM
‎2023-05-25
05:59 PM
Rubia Torres
Why is it so?
BTW, I used the slab tool...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-08 02:31 PM
In your cas you have just one elements.
Or you can try with LW to choose "internal engine material (?) fromdown.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-08 02:57 PM
Archi wrote:I have actually 5 elements. It's modeled the same way I would build it IRL.
You must have two elements for your solution. in order to indicate the separate direction.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-08 03:14 PM
You can fix it in the "Save As" approach by making two materials - horizontal for the rails and vertical for the panel and stiles. The one you are using will serve as the vertical material. Just make a copy and rotate the texture map in the material settings dialog.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-09 09:12 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-09 09:31 AM
Archi wrote:Is it really a custom object component? It's when I use the door component as a door panel on a kitchen cabinet the texture direction resets. Was ist los?
I tried with this way, and it works.
/M
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-09 09:58 AM
You can control the angle through LW-materila.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-09 10:25 AM
Archi wrote:Thanks!
You need simply two or three kind of materials. You can give different direction for every material.
I think it's also depending on which element I use... I will do a thorough test later on. I just tried using the mesh tool for creating beveled pieces to get a more realistic looking panel and it works all the way.I just need to figure out why I can't move the handle vertically...but after that I'm pretty in love with this new possibility to become a kitchen designer...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-09 11:09 AM
Your door handrail can be positioned little bit lower
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-08-09 04:25 PM
Archi wrote:Bitte!
It looks very nice!
I know but I can't manage to change the vertical position. It worked the firts time yesterday and I think it was only once...and then I havent been able to move it vertically. I will have to spend an evening pass on this to figure it out.
Basically I know how it all works.
