Tiff images not plotting? fills on top of .Tiff image
I have inserted .Tiff images in model space (In plan), I have added fills on top of the .Tiff images. I can see everything in model space. I created the view set and placed the the view on the sheet. Everything looks good in paper space. When I plot I can only see the fills and no the background .Tiff.
Is there a setting I am missing for transparency? Is my pen set wrong?
Need help.
Thx,
14 REPLIES 14
Are the TIFFs not plotting at all or just where they are obscured by fills?
amadoraaa wrote:
...model space ... paper space...
Need help.
Thx,
I think you want the AutoCAD forum
Hello Again,
I am not using AutoCAD but rather ArchiCAD. (Thx for the rude comment)
The .tiff images are not plotting at all. I can see the fills over the tiffs which are plotting fine.
I have gone back and turned the .tiff images from a bitmap to a gray scale image. That seemed to help but it will only plot sometime. Once I went to save it told me there was not enough memory in the heap zone.
I shall play with this some more...
Any other suggestions would be helpful.
Thx,
Aaron Bourgoin
Is this an example of this problem?
http://www.archicadwiki.com/Bugs/Drawings_with_images_do_not_print
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
Still have the problem. Going to try to convert the image to a JPEG.
Any advise would still be helpful.
Thx,
Rick Thompson
Probably not it, but I was having problems plotting tiffs until I started "bringing to front" the image, which was on a master sheet. You case sounds different, but just in case...
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Steve Jepson
Do you have the same problem if you print to .pdf first ? Then print the .pdf?
Converting the .Tiff file to a .Jpeg seemed to do the trick. I have been printing to .pdf everytime in order to conserve paper.
Thanks for all the help.
David Bearss
I have had problems printing tiff images to pdf in the past and found that png format is more universal and seems to work well. Still have an occasional situation where the image shows in the pdf but is dropped in the printing. Creates some confusing phone conversations when I send the pdf files to be printed and the contractor calls looking for the dropped detail.
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
