2025-08-14 11:52 AM
Hi.
I am trying to figure out if Archicad (out of the box) is really suitable software for producing Oak\Timber frame & Softwood panel fabrication drawings.
Whilst Archicad is great for typical construction methods it doesn’t appear to be a great solution when trying to incorporate Oak framing. At least not without the use of either third party add-ons (additional cost) or GDL coding knowledge.
I would like to produce accurate take-offs/cutting lists and fabrication drawings ideally for Oak/Timber frames and Softwood panels detailing the framing.
There doesn’t appear to be a user friendly (out of the box) method of achieving this, with wall tool object for the latter seeming very clunky.
Perhaps a shift to Revit may be the best solution (research pending).
Any advice or experience with this would be most appreciated.
2025-08-14 02:51 PM - edited 2025-08-14 02:52 PM
I am not the right person to answer this because I have never done this type of work in Archicad, but it may be useful if you could post a few screenshots/PDFs that would show the type of output you are aiming to produce and then users would be able to give recommendations.
One thing I can say is that I recommend checking out the capabilities of the Curtain Wall tool (may not be an obvious choice), I think you can achieve a lot with its use.
2 weeks ago
Hi Laszlo, thanks for the reply.
The Oak frame side of the fabrication drawings would be a 2D drawing of a frame made up with beams and columns, ideally with each piece/beam/column having a visible number label assigned to it for reference.
I have had a play around with the curtain wall tool for the softwood panel application, but at first glance it doesn't seem overly user friendly and doesn't allow more than one panel/sheathing layer to be applied. i.e I could create a basic panel with stud work and one OSB layer, but not multiple layers.
It may be that I need to explore it a bit further.
2 weeks ago
You may need to use the "CW Composite Panel" panel type to achieve those multiple panel layers.
Yes, the Curtain Wall tools is a complex tool but I think it is quite capable.
2 weeks ago
That's great, I hadn't spotted that.
I haven't tried more complex shapes yet, but this is definitely one step closer to ticking all the boxes regarding functionality, even if it is a little complex and un-intuitive.
Thanks.
