2011-05-03 09:34 AM - last edited on 2023-05-26 02:59 PM by Rubia Torres
2011-05-21 11:24 PM
2011-05-22 02:00 AM
Link wrote:True, that magic-wanding a will will get rid of the polygon count issue most of the time. (Not all of the time, as it seems that some times magic wanding a curved area results in a curved fill that does not precisely align with the original - depends on magic wand settings/etc.)
All is not lost! If you fill the inside of the 'X' with an empty fill, it should nullify the polygon count issue.
2022-07-04 07:30 PM
I've been using the method of different fills in a complex profile to create the 'X' in section as suggested above and actually used the the technique by ContraBim of creating a chamfered corner so multi-ply studs and beams are defined in 3D more clearly. Up until now this has worked well for me. The problem is that we are in the process of implementing Vertex BD which is a 3rd party software for creating detailed framing drawings and outputting to CNC machines for cutting and assembly (similar to ArchiFrame but way more intuitive in my opinion.)
We are exporting an IFC model and then converting the walls, floors roofs and beams into Vertex objects which works smoothly for the most part. The exception is with my beams or columns that were placed in AC. If I convert one of these complex profiles into a Vertex profile the IFC model splits each fill into (4) separate triangle shaped profiles. I get around it by only converting one of the profiles but it is quite annoying because I have to make sure I choose the same triangle for each one or they end up at different reference levels.
For columns you can just use a rectangle and turn on the crosshairs set to an 'X' but there is no way I can see to do the same for beams. This would be very useful for visualization purposes before exporting for the framing model to be produced.
It's probably a lot more complicated to incorporate a simple 'X' when beams are shown in section in AC than I realize and maybe that's why it's not done yet but I feel like there would be enough people with this want to make it worth while for Graphisoft to try and add it in an updated version. And maybe a tick box in the column/beam floorplan & section settings to prevent fills from merging if they are in say two beams that are adjacent to each other as in a multi-ply wood beam or column. Or maybe that would be in the fill settings when creating the complex profile.
