Tips to work with Guide Lines
Guide Lines are drafting aids which help you find special points and projections, to ensure precise input in both 2D and 3D windows. Guide Lines are based on the cursor’s relationship to the input plane and to existing elements.
1 - Show/Hide Guide Lines
To hide the existing Guide Lines or to make them visible, use: • The toggle button in the Standard toolbar • The L key as a predefined shortcut (toggle Guide Lines on and off) • The View menu > Guide Lines toggle command
2 - Guide Lines Options
Click the pop-up menu to access Guide Line options. • Create Guide Line Segment • Remove All Guide Lines • Main-direction Guide Lines • Relative-direction Guide Lines • Incremental Angles
3 - Force Guide Line Display Shortcut
“Force Guide Line Display” is a keyboard shortcut that makes using Guide Lines even smoother. Since ARCHICAD 16, the predefined shortcut for this command is the Q key. Use this shortcut when you want to: • Make multi-choice Guide Lines appear during element input without having to press the mouse button. Note: Your cursor needs to be resting on any point of the element for this to work. • Create or activate a Guide Line along an edge without having to click the Guide Line handle. • Grab and move the Guide Line with your cursor without having to click the Guide Line handle. Note: Your cursor must be over top of the Guide Line handle (the orange dot) for this to work.
4 - Constrain Cursor to Guide Lines
To constrain the cursor to the nearest Guide Line, press Shift during input. Note: This works if the Instant Guide Lines box and/or Lasting Guide Lines box is checked in Options > Work Environment > Mouse Constraints and Methods. (They are checked by default).
5 - Place an Orthogonal Guide Line using Ruler
At any time, click on the Ruler at the top or left edge of the screen, and then drag your cursor to anywhere in the window: a Guide Line parallel to the Ruler is created.
6 - Guide Line Angles and Colors
Use Guide Lines Settings in the Work Environment to define your preferred angle increments and to set default Guide Line colors: go to Options > Work Environment > Guide Lines.
Browse more articles
Back to articles
