vfrontiers
Title types are SWITCHING at will
Ok... I did a quick search (admittedly, I am not very good at searching)... But is anyone else having TITLE TYPES switch when closing then opening a Plan file?
I have changed MANY title types SEVERAL times only to find that when I re open the file, they have switched back to the FIRST TITLE TYPE in the list of available title types.
I can think that there are a few possibilities...like the two title types share an internal ID, but they are really not related to each other (I didn't save one AS the other)...
Some mechanism might be replacing this title with the current default each time I open the file.
Anyway... what do you know?
Help... this makes producing hard copy incredibly suspect.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
1 Reply 1
It sounds like this: http://archicad-talk.graphisoft.com/viewtopic.php?p=99745
Supposedly it was hotfixed a patch or two ago. Before that, I found I could fix it by re-placing the drawing, but that didn't work for everyone.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
