multi window colour change
I have a building with a lot of different sized windows and I need to change the frames to a different colour, is there a way to do all of them at once or can I only do it individually?
Thanks
You should be able to change them all at once. Select them and only change the relevant material parameter. (There's always UNDO if it doesn't work )
Worked great.
Thanks a lot
