Toolbar in Archicad 9 for Mac
will there be a toolbar available for the mac version of Arhicad 9? What´s the reason that it has been left out for previous versions? It is very annoying since I´m used to work on the pc-version.
Is there any third company who have developed a plug-in for the mac version which gives the program the toolbar?
sincerely,
Jostein Korsnes
4 Replies 4
Djordje
Yes, programmable as the rest of the interface.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
__archiben
joskor wrote:
...will there be a toolbar available for the mac version of Arhicad 9?
kind of a toolbar . . .
basically, what they've done is create a whole bunch of mini floating palettes that behave slightly differently to the usual floating palettes. when you first open archiCAD you get about 7 or 8 of them all in a line across the top.
because they snap to each other (as all floating palettes in 9), you can pick up the first one and all the attached move with it - ala photoshop CS. but: the more docked toolbars, the more system drain when you do move them, and the more space wasted with the sideways titleblock and close button.
as djordje says: it's completely programmable - just like the rest of the interface - so i've made one solid, easy to move toolbar.
right then. i'm sure sharing 'work environments' will probably deserve it's own topic or forum somewhere when 9 really gets going (djordje?), but for now attached is my 'work environment' profile. it works for a 15" apple powerbook (res. 1280x854), but can be modified to any resolution quite easily. simply extract it and import it from the work environment setup (Options>Work Environment...>Work Environment Profiles>Import)
(if anybody does try it, remember: the info box is now scrollable with the mouse wheel and the ` key brings up the navigator . . .)
you can of course import just the separate schemes one-by-one if you wish so that you can get the the toolbar only and apply it to your own palettes and shortcuts, etc...
~/archiben
b e n _ f r o s t
Djordje
Aside from the betas, obviously some people received their 9s already.
I don't think we need a new forum, but we do need new 9 topics.
Therefore, PLEASE, EVERYBODY:
STATE YOUR ARCHICAD VERSION!!!!!
Otherwise it will be a pretty mess, as there are people here still on 6.o ...
Djordje
HP Omen
__archiben
sorry djordje.
was i jumping the gun a little bit?
~/archiben
b e n _ f r o s t
