‎2019-10-1709:36 AM - last edited on ‎2023-05-1910:40 PM by Gordana Radonic
‎2019-10-1709:36 AM
is there a way without solid operations/ complex profiles or morphs to make a wall with a sloped top? i have a bunch of wall fences laid out on an uneven terrain, so in order to control the height at specific points the top needs to be adjustable.
Complex profiles are not easy to work with especially for a lot of walls, morphs also are not easy to manipulate like walls, you cant just drag a points.
Essentially the ideal solution would be a wall that i can grab a point and lift it up on z where it fits me.
As Lining has suggested, check your rail connections.
I have shown it using a 'rail' instead of a 'top rail'.
But it is the same.
In fact using a 'top rail' is easier as the rail height is calculated from the top of the rail.
With a 'rail', the height is measured to the centre of the rail.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
