Trace Reference
Hi, dose anybody knows why when I turn my trace reference on the computer became very, very slow.
Thanks
4 REPLIES 4
Thomas Holm
Select your trace reference from the Navigator's Project map, not the view or layout map. This way Archicad doesn't have to deal with different layer combos simultaneously, which speeds up things a bit.
Erich
I also found it to be a lot slower in AC 11 than AC 12 - not that it helps your problem but if/when you upgrade you could see a boost in performance.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Thank you for the tip.
Thomas Holm
You could also customize what the trace reference shows, in it's settings dialog, turn off everything non-essential.
