Learn more
Michael Chacon
Trace Reference
Anyone know how to disassociate a Trace Reference from a view?
7 Replies 7
Laura Yanoviak
Turn it off (Hide it).
Stress Co_
How do you remove it from the Trace "reference pulldown list"?
Marc Corney, Architect
Red Canoe Architecture, P. A.
__archiben
you can't. i asked for a 'clear current ghosts(!)' command during beta. maybe they'd already changed to 'trace reference' by then and didn't understand what i meant
~/archiben
b e n _ f r o s t
This is by no means a great solution. But if the trace reference you have is part of the layout book or the view map you can delete the actual reference and re-save it.
Obviously if you done a heap of work on the layout itself then it doesn't really help, but its somethign I found out as I was developing this template and as I deleted old layouts etc they disappeared off the trace list
Certainly it would be much easier if GS made a simple remove reference option.
Stress Co_
When your in beta for 12.... maybe ask for a clear trace colors too?
Scott Bulmer
In addition to the other answers here, I believe you can also force an unwanted Trace off the list by adding others. I think a user can have up to 5 traces per view, so in theory you could keep pushing the unwanted Trace to the bottom, then off the list when it becomes no. 6.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Stress Co_
Scott:
Does it work for you? The attached has about 26 references. References that were selected as references, for other views.
