Learn more
Trace Reference
After upgrading to build 1200 I now can't seem to get a layout sheet with a PDF placed on it to work as a trace reference.
(And yes AC was closed when I upgraded).
The layout shows up as available in Trace Reference but will not become visible, no mater what combination of sliders, position, on/off etc. I choose.
If I place the same PDF on it's own story, I can use it as a Trace Ref, but not
when it is on it's own layout sheet.
Anyone else seen this with build 1200?
2 Replies 2
Works fine with me... MacBook Pro Leopard ArchiCAD 11 /1200
Now new issue with T.R. build 1200
Since I could not get the Trace Reference to show PDF on it's own layout, I put the PDF on it's own story, seemed fine at first, but then in Trace Reference when I pan in and out the Active view gets warped, where as the Trace looks normal. The PDF has been rotated, but don't think thats the problem.
At about 21% the both views look normal, screen shot shows about 40% zoom. When at 100% Active is turned into a small parallelogram! (Not shown)
What the???
