Palawat
Tracker is not updated.
After I input numeric data (x,y coordination) into tracker, it won't update automatically. The numbers are only updated when I press up and down arrow to switch between the fields in tracker. Does anybody has any idea about this or do I have to set up anything?
Best Regards,
palawat
Archicad 29, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
2 Replies 2
Palawat
aah....got it !!!
i work with two monitors and if i set them to "horizomtal span" mode, tracker doesn't update the number as i type. but if i set it to "standard (Dual view)". it works just fine.
just think it might be useful for anyone with the same problem.
Are you running ArchiCAD on windows xp? If so, can you please ensure that you have downloaded and installed the latest service packs?
FYI
http://support.microsoft.com/kb/814135/en-us
