‎2006-08-28
12:38 AM
- last edited on
‎2023-05-26
12:35 PM
by
Rubia Torres
‎2006-08-28 01:44 AM
‎2006-08-28 01:58 AM
Peter wrote:Or, if you do not want to reconstruct everything use SEO. Place a small slab on a layer called SEO and subtract. Assuming Peter is correct in you wanting a plumb cut.
I believe you mean plumb cut when you say "flush cut".
Use the roof tool with the eave and ridge edges set to perpendicular.
Peter Devlin
‎2006-08-28 02:17 AM
‎2006-08-28 02:20 AM
‎2006-08-28 03:44 PM
Peter wrote:Thanks Peter, I hadn't used sloping beams. Just took the description literally.
Rod,
I am assuming that he does NOT want a plumb cut.
AC 10s sloped beam always makes a plumb cut.
Peter Devlin
deivclayton wrote:But now I'm really confused! ':)'
Yes, I did mean a plumb cut when I said flush. Thanks for the response-- I found the roof tool works just fine for what I'm doing.
‎2006-08-28 04:19 PM
