Transparency
Hi, I am working on 15 and I create a custom panel door. I choose the right material fro the glass and for the style and rail. when i generate any 3D or Elevatins I cann'ot see the trasparency.
Please any suggestion and help.
Thanks
9 Replies 9
vfrontiers
I have to ask,
1. Is TRANSPARENCY set to ON in the 3d Window Settings?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
I already checked that parameter but it is on, I was wondering if it has something to do with the renovation filter and where the panel is created, in wich environment.
Thanks
vfrontiers
Might be...
2 things to remember/do
1. Make another Renovation Filter ALL ON
- SHOW ALL (as-is)
2. 3d window has it's own unique Renovation Filter Status
- Going from 2d to 3d DOES NOTE keep the same renovation filter
- You may have to switch it in the 3d environment
Duane
Visual Frontiers
AC3.14 - AC29
Thanks for your answer and help but even with all you suggestion nothing happened always the same story.This picture show my problem.
Again thanks
vfrontiers
Make sure the WINDOW MATERIALs are set to
USE OBJECTS MATERIAL as opposed to one override material...
I can't tell if the materials shown in your picture are all the same...
If you change materials, to say something RED... does everything change? or nothing...
Duane
Visual Frontiers
AC3.14 - AC29
Thank you for your help and suggestions.
I remade the panel and everything looks alright. I have no idea what happened.
Hi, I thought the problem was solved, but today when I spin the model one side of the door is trasparent the other site is like lead. Any suggestions?
Thanks
vfrontiers
When creating your object, make sure the same glass MATERIAL is on ALL SURFACES...
Duane
Visual Frontiers
AC3.14 - AC29
Thank you it was the slab I used for the glass was different material.
Thank you again
