Meshes from ArchiCAD 14 not showing in 15
Sloan Springer
I recently upgraded to AC15, but on all my files from AC14, none of the topography meshes show up in 3D, only on 2D...any ideas??
Sloan Springer, AIA
www.springer.archi
ArchiCAD 24 Solo\\ 2017 MacBook Pro 13" \ 2.3 GHz Intel Core i5 \ 16 GB RAM \ macOS Catalina 10.15.7
5 REPLIES 5
Eduardo Rolon
Check your renovation status.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Sloan Springer
Rennovation status is "Existing"
I just noticed as well that the mesh also does show up on sections...only invisible in 3D
Sloan Springer, AIA
www.springer.archi
Eduardo Rolon
If the mesh is not shown in 3D then it will disappear from the sections and elevations so it is the same problem.
Besides checking the Active Renovation Status you can check that the Tag for the Mesh is also Existing.
Also you can try selecting the mesh in floor plan and then use "Show Selection in 3D" to see if it pop's up.
Also verify your View Sets
You might also try to copy paste it from AC14 file to your AC15 file.
AC28 US/INT -> AC08
another Moderator
Sloan Springer
Thats the weird thing, it shows up fine in all sections and plans, but just not in 3D
Copying and pasting didn't work either, so I just decided to spend my time remaking it from a DWG out of 14...thats working so far at least!
Sloan Springer, AIA
www.springer.archi
David Larrew
This may seem elementary... You might try checking your "Filter Elements in 3D" filter to make sure that "Meshes" are visible.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
