Trapezoid Volume
Hi, in one of my designs I'd like to use a trapezoid volume. Is the only way to create one through a boolean operation? Or is there an object available that I can use? I'm not sure....
I'm using Archicad 11 on a Mac
Thanks and Kindest,
Peter de Ruijter, The Netherlands
7 REPLIES 7
rocorona
What about of a Mesh?
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
thanks for your reply, but I'm not sure how this would help me. A regular sloped mesh would give some options, however a trapezoid has slanted sides / walls. Can this be done with a mesh?
Peter -
Dwight
As long as the top edges never overhang the bottom ones.
Dwight Atkinson
Do you specifically need it to be a solid volume? Could you use four sloping walls instead in this situation?
You could even investigate making a GDL object if it's something you might use often. Each node could be X, Y & Z adjustable using hotspots!
Erika Epstein
In the US version of archicad there is a standard library part
special Construction>Polygon Prism 11
which gives you the mass you posted.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
It is strange that the programmers at Gralphisoft named this object
"Polygon Prism" since I believe this shape is referred to as a
"truncated pyramid" in most mathematical texts.
I wonder what the issue for the programmers was that caused
them to decide on this name.
Peter Devlin
Erika Epstein
Don't know about the limitations if any using the math term truncated prism. I wondered if the name was to indicate that the section can have 3 ore more sides. The top plan can be angled.
I've found this a useful little library part for footings to faux rocks.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
