HelenE
Turning insulation around windows and doors
Hello everyone!
I have been trying unsuccessfully to turn the insulation around the doors of this building. I know it has something to do with the tab "Wall closure" but I haven't figured it out. The wall is a composite. All I've managed to do is turn the plaster... Does anyone know how to do this?
13 Replies 13
hevi
Ace
Nothing obviously wrong. Perhaps it has to to with the inside/outside of the wall composite. Is the insulation towards the inside or the outside?
In wall closure dialog change Select Skin to Edit to Outside face and select Turn-in Skin for the 1. Skin and 2.Skin
HelenE
Thank you for your reply, I really appreciate it! The insulation is towards the inside of the wall composite. I tried what you said, it makes sense but unfortunately it didn't change anything. Screenshot_6.jpg
hevi
Ace
Okay. No - with that composite the settings were right in the first screenshot
I didn't look carefully at the plan screenshot... it looks like the door's Floor Plan Display is set to Projected. If so - change it to Symbolic.
Wall closures are 2D-symbols so it won't show when the door/window is set to projected.
HelenE
Success!!! I never would've thought of that! Thank you ever so much!!! Screenshot_7.jpg
