U-Shape stair bug
Hi! I noticed a bug in U-Shape stair in ArchiCAD 16.
For example I want to create stair, with 22 risers (11 risers on each run), and with 150 mm Tread height.
22×150=3300.
If Parameter Type set to "Tread Height", then all working fine. I'm setting Height to 3300, no. of risers 11 and 11, and getting 150 tread height automatically.
Now I set Parameter Type to "No. of Risers per Run". When I set no. of risers 11 for each run and tread height 150, I get stair height 3450, instead of 3300.
5 Replies 5
I've converted the stair to Morph, and measured real tread height - 156.8 mm.
I can reproduce what you see. Sure seems like a bug. When in 'no risers' mode like you, I have to enter 143.5mm as the 'preferred tread height' for the model to actually be 150mm. Really strange.
I'll submit a bug report.
Bug confirmed by tech support. No delivery date for the fix, so one of the workarounds below must be used for now. Sorry.
Still not fixed in ArchiCAD 17!
Still not fixed in ArchiCAD 19!
