UGLASS
I need help. I want to do a curtain wall of the type UGLASS, but i dont know how to do it in ARCHICAD. Please
6 Replies 6
Unless you tell us which uglass curtainwall, and if you are running ArchiCAD 12 with the curtainwall tool, or an earlier version, none of us will have a clue as to what you want or how to help you.
Karl
Hello Karl, I have the archicad 12 installed. I want to do a curtain wall composed by double layer of low iron UGLASS profile units (nominal 60 mm) an aluminium frame system.
Karl, I refer to glass pieces with form of channel, as the frontage of steven's hall atkins museum . A translucent U-shaped cast glass produced in several widths ranging from 9" - 19" and lengths to 23 feet.
rocorona
As I've just replied on ArchiRADAR, you can achieve this creating a new CW panel.
- Create a new Complex Profile, shaped as a reversed "U";
- Place a BEAM with that complex profile on the floor plan, along the Y axis (if you want the glass to be vertical, as normal);
- Select the Beam, and go to File>Library and objects>Save custom component... Save it as Custom CW Panel.
Then set up your CurtainWall.
- Give to the grid the dimension of the glass element. You can set a simple 1x1 grid;
- For the panels, choose the Custom Panel CW 12. In the parameter list, at "Panel name", select the object you create;
- Make the mullions/transoms "Invisible".
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
thanks a lot, i´ll try it.
rocorona
Here is a simple example.
_________________
--Roberto Corona--
www.archiradar.com
_________________
_________________
