Undo command
How far back can a user undo actions?
10 REPLIES 10
Rakela Raul
options / work environment / data safety / undo limit (@ the bottom)
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Thanks. And are there any actions that can not be Undone or Redone?
Dwight
Yes, but it warns you first - like section deletions.....
I also just discovered that a complex profile, once changed, can't be undone automatically - it must be done manually.
Dwight Atkinson
... and you can't undo beyond a Save.
Dwight
Many times i wish that a "Save" could be undone.
Dwight Atkinson
Probably should be in wishlist - the undo list should be accessible so that only user selected ones can be undone (if so desired) in no particular order - I have seen similar on other software
Related to the Undo command. one of my favorite Autocad commands was OOPS. You could delete a bunch of items, carry on doing stuff, then go OOPS and the last set of items deleted returned. It was handy for all sorts of things, not just mistakes.
Link
An existing wish is to introduce a History, like Photoshop, where we could go back to specific commands and undo them.
Link.
Link.
Unfortunately PS's History isn't an individual action undo, but it undoes ALL the way back to the history item. You'd think in 2008, software would enable you to undo a single item no matter where it is in the history list.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 27 (user since 3.4, 1991)
16" MacBook Pro; M1 Max (2021), 32GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
