DataChris
Unlock Coordinate
I'm working in 9 (but noticed the same problem in 10).
Where is (or what happened to) the command to Unlock a locked (x,y) coordinate?! I can still click on the locked coordinate to unlock it but I used to be able to use option-spacebar to unlock the coordinate.
Digging through the keyboard shortcuts the command simply doesn't exist (at least not that I can find).
Any solutions?!
Design loving, technology geek. USA
Archicad (v28) - MacOS (15.4) - MacbookPro (M4Pro)
David Maudlin
DataChris:
The way to lock or unlock coordinates (x, y, r, a) is to press option & the coordinate key (x, y, r or a). If the coordinate is locked, then this key combination will unlock it. This is for the Mac, use Alt key on Windows.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
