Update build 4044
Can this update be installed over older build numbers, or do you need to install all of the updates in order? We are running build 3636 and wondered if I could skip build 3862.
Eduardo Rolon
AFAIK the latest updates always include previous updates that you might have missed.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
You are OK to skip the update as each Hotfix gets larger in size as it contains all the updates from all the previous Hotfixes as well as the current.
