2023-03-10
		11:45 AM
		2023-05-09
		02:00 PM
			Rubia Torres
I upgraded my Archicad to the 26 Version and everything works just fine with the exception of the shown elements and lines getting displayed in a weird, pixely way (take a look at the pictures). Zooming in and out doesn't look how it supposed to do. It looks like there are 2 Lines in the same position. Is this a Archicad setting thing or has this something to do with my PC? But Archicad 25 works just the it should so I guess it is an Archicad setting problem right?
Thanks for your help 🙂
Solved! Go to Solution.
2023-03-10 03:22 PM
Archicad 25 uses open GL while Archicad 26 uses directX. Make sure your graphic card and the driver is capable.
2023-03-10 11:53 AM
You haven't got a duplicate showing as a trace reference have you? Make sure your Trace and Reference is turned off.
2023-03-10 12:01 PM
do you have 2d antialising turned on?
options > work environment > advanced redraw.
2023-03-10 03:22 PM
