TAhrens
Upgrade problems to ARC 26
I upgraded my Archicad to the 26 Version and everything works just fine with the exception of the shown elements and lines getting displayed in a weird, pixely way (take a look at the pictures). Zooming in and out doesn't look how it supposed to do. It looks like there are 2 Lines in the same position. Is this a Archicad setting thing or has this something to do with my PC? But Archicad 25 works just the it should so I guess it is an Archicad setting problem right?
Thanks for your help 🙂
1 Solution
Markus Denzlinger
Archicad 25 uses open GL while Archicad 26 uses directX. Make sure your graphic card and the driver is capable.
Go to post
3 Replies 3
Lee Hankins
You haven't got a duplicate showing as a trace reference have you? Make sure your Trace and Reference is turned off.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Emre Senoglu
do you have 2d antialising turned on?
options > work environment > advanced redraw.
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
Markus Denzlinger
